Topaz 2.0.2 seems to slow to a near stop when in the processing queue. GPU RTX 2060 Processor 11th Gen Intel(R) Core™ i7-11700KF @ 3.60GHz 3.60 GHz
Installed RAM 64.0 GB (63.9 GB usable)
@toby.long Let’s try updating your graphics card drivers using this link: Download NVIDIA, GeForce, Quadro, and Tesla Drivers
It might also be a good idea to rerun the installer in case you’re missing model files. Please disable antivirus, firewall, VPN, or proxy that may be on your computer. These are known to block the installer from downloading the model files.
That seems to have worked. I will keep an eye on it. Thank you for the very prompt fix. Toby
