Hello,
i am using version 7.3.2. (actualy trying to install 8.1.1. Trial for test). I’d like to ask why GigaPixel software doesn’t utilize CPU or GPU. When resampling images it takes quite long time, but CPU (12 Cores - dual Xeon) runs approximately around 20% and just few cores… i would expect that it will utilize hardware as much as possible. Even when I try to switch to GPU (which si not that bad), it runs maximum 40% of its capacity. Harware detail specs follows. Do I really need latest hardware?
Now i will try version 8, just in case the version 7.3.2. i am licensed was badly written…
thanks for advice
Marcel
System Information
Time of this report: 1/7/2025, 23:48:11
Machine name:
Machine Id: {A3FE62BE-606D-47EF-9A9B-3A716BD0DCEF}
Operating System: Windows 10 Pro 64-bit (10.0, Build 19045) (19041.vb_release.191206-1406)
Language: Czech (Regional Setting: Czech)
System Manufacturer: LENOVO
System Model: 30A8S1W700
BIOS: LENOVO BIOS Rev: A5KTACA 0.0 (type: BIOS)
Processor: Intel(R) Xeon(R) CPU E5-2620 v3 @ 2.40GHz (24 CPUs), ~2.4GHz
Memory: 32768MB RAM
Available OS Memory: 32666MB RAM
Page File: 7246MB used, 58186MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, no HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.0.8
DxDiag Version: 10.00.19041.5198 64bit Unicode
Card name: NVIDIA GeForce RTX 3050
Manufacturer: NVIDIA
Chip type: NVIDIA GeForce RTX 3050
DAC type: Integrated RAMDAC
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_10DE&DEV_2584&SUBSYS_258410DE&REV_A1
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 22334 MB
Dedicated Memory: 6002 MB
Shared Memory: 16332 MB
Current Mode: 2560 x 1440 (32 bit) (59Hz)
HDR Support: Not Supported
Display Topology: Extend
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.639648,0.330078), Green(0.299805,0.599609), Blue(0.150391,0.059570), White Point(0.313477,0.329102)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Dell U2722D (DP)
Monitor Model: DELL U2722D
Monitor Id: DEL422D
Native Mode: 2560 x 1440(p) (59.951Hz)
Output Type: Displayport External
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported
Driver File Version: 32.00.0015.6636 (English)
Driver Version: 32.0.15.6636
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.7
Hardware Scheduling: Supported:True Enabled:False
Graphics Preemption: Pixel
Compute Preemption: Dispatch
Miracast: Not Supported
Detachable GPU: No
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: 3.12.2024 1:00:00, 814784 bytes
