Slow Motion Render Generating Strange Artifacts
You should be able to see the issue as well as the settings based on the screenshot. System info:
MacBook Pro (13-inch, M1, 2020)
Mac OS version 11.6
M1 Chip 8 GB Memory
This is after latest Video AI update. Hasn’t had any issues prior to this.
Hi there, unfortunately, your Mac does not meet our system requirements. We require at least 16GB of RAM, however, I do not believe that this is why this is occurring.
Does this occur when Themis is not enabled?
Please share the input file with me (if you are able to) and the exact reproduction steps.
You can securely submit your files(s) to our Dropbox using the link below. Please be sure to send me a note to let me know you sent something.
Submit File to Dropbox
Based on the experiments I’ve run it’s the Apollo model only that’s having this issue. I don’t know what an input file is.
Robert L. Poole
(615) 579-6100
robert@rpcmedia.com
The file you put into tvai when this issue occurred.
Are you still having this issue with v3.3? If so, I would really like to take a look at the input file and test this on my end.
