Uploaded a file of over 1800 images. I have done this in the past. Just updated Photo AI. I select the improvements I want for the images. I select all. The program goes through the first file no problem. Then it skips the remaining files. lastSessionFiles.txt (268.5 KB)
Steps to reproduce issue:
Step 1 Loaded the images
Step 2 Selected the enhancements I wanted for files.
Step 3 Select all and choose the address for the files to be saved to
In the new v3.1.0, the developers and product team changed the Auto-Pilot’s default behavior. It now suggests that by default, instead of applying, this could be why you are having this Skipped Error message.
To put the Auto-Pilot back on so it applies the suggestions automatically, please follow these steps:
Open the Topaz Photo AI as a standalone application.
Go to Preferences > Autopilot and enable Automatically apply filters to on and click Apply.
After you have done this, you should be able to use batch processing to work through your images.
