I often need to crop pictures of distant birds from an otherwise empty blue sky. Knowing that super focus wants a 6k or greater shot, it would be helpful to see the dimensions of the proposed cropped area as one uses the cropping tool. There is already a place to show this: the field currently used to show the pre-cropping dimensions (which one probably knew before embarking on the edit).
Cheers
MM
