The keyboard shortcuts for increasing and decreasing the brush size and for adjusting feathering are not working.
I’m using a Swedish keyboard, and the menu says the shortcuts are Ä, Ö, Shift + Ä, and Shift + Ö.
Topaz Photo AI [v2.0.0] on Mac
Can you take a screenshot of the shortcuts you are seeing? Was it working before?
You can also try setting new shortcuts. By default, the shortcut to increase and decrease brush size is [ and ].
These are the ones shown in the menu:
Now when I check the preferences, I see that the default shortcuts you mentioned are shown there.
[ and ] can’t be used as shortcuts on Swedish keyboards (this is a constant headache for us with software developed in the US, because you love to use [ and ] as shortcuts ), so that’s probably why this isn’t working. But now I know I can change them. Thank you!
I appreciate your understanding about this.
Please let me know if I can help with anything else!
