I suspect the problem might have been a bad update installer, I recommend you uninstall the app completely and reinstall with the link below; this will get you a new license for 2.3.0
If the issue persists, then it’s likely a bug in the update version itself, which, in that case, I’ve provided the 2.2 version below for you to revert to!
