Sharpen AI v4.1.0
Thank you. I’m afraid I can’t identify a blue callout on the first page of the official website. Would you be sooooo kind as to send me a screen shot of the callout you refer to?
Make sure popups are not blocked by your browser … you can see it on every page of the website …
Deleted
This isn’t ON1, he is talking about Topaz Sharpen AI.
Stupid of me. I have deleted the post
Here’s what the button looks like in Safari. Note that I have pop-ups blocked for Topaz but it is still showing.
I think I got it right this time!
So many thanks: indeed my browser was blocking these popups. You made my day…
Have I found a new bug in version 4.1.0 (Windows)? When I change the brush size in “Refine” of the selection, the opacity of the selection changes to the same value!
Thank you for your answer. That shows us, how intrested you are in your customers.
Just raise a support request at the main website… this is a user to user forum.
Hi… downloaded the trial version of Sharpen AI with a view to buying… I have been testing all day various .dng files in the stand alone by just dropping the image into the program… does a decent job of removing noise and sharpening.
however on saving (as .dng) I get a much brighter image than the original with lots of artifacts in the shadow areas that look like nasty colored noise similar to when brightening an underexposed image… I am willing to supply the specific image for your testing… tnx /p
I suggest trial Photo AI, it has updated Sharpening, as Sharpen AI is not going to be updated according to Topaz Labs,
I tried Photo AI also but I need to buy the licence before I can export to see the results in Lightroom,… after my experience with Sharpen AI exporting a brighter image than the original I am not prepared to buy a program just to see if it will do the same then have to request refund…
hence I am leaning towards DXO photolab with is about $60 more than Photo AI… and I can export without any watermarks for the next 30 days… Topaz should have enabled exporting with watermark insted of forcing me to buy the program before I can export.
You do have a 30 money back guarantee, no questions asked.
BTW DxO Photolab is a good option also, I just finished a trial but I would wait to see what v7 brings very soon.
Is this for certain? No more updates to Sharpen AI? If so, disappointing!!!
