Ok Ray, thank for checking. I’ll test it again tomorrow when I reboot my computer.
Update: After re-booting my computer this morning, as I do every day, I could not reproduce the over sharpening problem on DNG files of my original post. I deleted the original post.
Much to my chagrin, the v4 version install overwrote my v3 (on Windows 10).
a) without asking about an alternate install dir
b) without warning about the overwrite
So, I would actually prefer a new dir…and those experienced with dot-zero releases would be wise to do so as well. Overwriting a previous version should not be SOP, particularly without warning.
It would be nice to have some info/documentation on the new Standard model with the 2 choices for blur type and the 3 slider controls. The sum total of the documentation seems to be this:
I believe that’s probably a bug in the current version of the app you have, which appears to be 3.2.X or below. I’d suggest manually downloading Sharpen 4.0.0, and it should correctly recognize you own the app.
God. please help me, can any kind developer provide a download link to all the model files? I’ve been tossing and turning for over an hour trying to download a new model, and every time the slow download process ends in a failure, I have no choice but to repeat, fail, repeat, fail… jeez!
Im having issues with 4.0 When I go to edit in sharpen from lightroom a box opens up after sharpen opens and says “Downloading model file” It takes 10-15 min to download file, then I cant select any changes or see the sharpening. Im working off a high speed SSD external drive plugged directly into my 2022 14" Macbook pro with M1pro chip.
I just installed Sharpen AI v4.0. I am having sorta the same issue. I loaded a picture, and every time I try to do anything it says it needs to download a file for this model before processing. It will finish the download, but the process starts all over when I click on anything.
Sharpen AI should open by itself after installing the update. Your plugin configurations should now be reset. Follow any prompts displayed relating to installing plugins.
Changes
Improved update dialog - now clarifies between owned and unowned updates
Added “Select All” hotkey (Ctrl/Cmd + A)
Improved performance for M1 macs with 8GB of RAM
Fixed plugin/standalone taking long time after pressing “cancel” to actually close
Fixed “Canceled” appearing in file list view while processing
Fixed files that have previously been canceled not processing the next time images are being saved
Fixed scrollbars disappearing while being held down
Fixed OpenGL models not loading correctly
Fixed in app updater getting stuck at 100% (updating to 4.0.1 may still fail)
Fixed “Apply” and “Cancel” buttons being non-functional sometimes
So my 16C Xeon workstation apparently does not support necessary functions for the new Standard Model - where do I find the CPU spec required (would be nice to have a link in the warning S.ai displays)?
Perhaps they are uninstalling the old version before updating. Since each version is not a new program but an update it only makes sense to install over the old version. Otherwise, you could have many large programs (different versions) installed and this can cause confusion. Beta programs install differently.
Sorry to strongly disagree; that is precisely why most app installers allow specifying the install dir.
Changing a major version (eg v3.x to v4.x) requires a new install dir, imo. That’s why the major version is bumped in the first place. This is from years of using that approach with professional admin work. Installing a new version over the top of a working version, not knowing if the new version works, is an invitation for a pink slip. I am surprised at the users (above) that take that leap of faith with commercial usage as it is begging to get burned. In fact, on multi-user systems it is not uncommon at all to have many versions installed in parallel and the user updates their login profile for the version they want on their execution path. Again, breaking someone’s research because you overwrote their software with a new version would likely get you fired or at the very least yelled at. Updating from a working version to a version with serious issues, without easy fallback, is considered very bad form.
The resource dir can/could be shared (eg from the models). Hopefully, that is what is happening.
