This release of Sharpen AI has the same problem that is still problem also with newest Denoise AI (v3.1.1): the program strips of GPS EXIF information (as Lightroom sees it). Have to go back to previous version also with this as I had to do with Denoise.
Hi! So itās great that there is an update, thanks for that, it is always good news, but itās a 2.0 gb download and itās only downloading at ~350 kb/s so itās taking forever. Same thing happened to me when I downloaded a trial for DeNoise a few days ago with its latest update to try it out, took forever to download.
So I got no problem with the installation files being large, but maybe you could take a look at why the download speeds are being so slow. Either improve on the file size of the program and make it smaller or the server speed. Itās taking more than 1 hour to download the fileā¦
Hello Topaz Labs and its customers,
I have just received an email reminder that a free update for Sharpen AI is available to me. Jolly good. However, in all the blogging in this section I cannot see a clearly defined āDownload Hereā, or similar signage.
A question for Topaz staffers: I am currently running Catalina on a Mac Pro and intend to do so until the end of 2021. Iām doing this as I wish to keep using another vendorās motion graphic plugins whilst they decide whether to reinstall the said plugins in one of their plugins suites. Will using and Topaz Labsā stills plugin, or Video Enhance AI not work if I keep taking your updates this year, whilst still running Catalina?
Installed Online W10 version. Updated very fast - just a couple of minutes to complete install.
One quick test with a mask ran fine and saved correctly and also fast
You can download either the online or full installer for Macs (just be sure you donāt grab a Win installer).
The online will be a faster install process (typically) but the product should work the same with either. If any issues with the one you choose, try the other.
According to me, Multi GPUs only worked in 3.0.0 (3x7950 HD - I7 3770k Delidded - 32GB - W10). Itās the only way to work āfastlyā for me.
I know this is an experimental feature, but if you could solve this bug in >=3.0.1 I would be grateful ! (That would stop the emotionnal rollecoaster I feel at every new version and avoid me to roll back to 3.0.0 every time).
Another thing would be to optimize the cursor in masking. Itās a pain to use in 2021 (why not using mouse wheel to increase/decrease the size of the cursor, and press āAltā to substract mask ?).
And last thing why such differences between CPU and GPU processing ? (CPU is still better)
This will be my first update and I am confused about the difference between āonlineā and āfullā The full whatever is humongous and the online whatever is only 7.3 MB. I donāt want to mess up my existing version. Which to do? I am running on a Mac Mini M1. I do not run from a host app.
