Just installed Sharpen AI latest version, and use Lightroom to edit my photos.
I am running an M1 Mac mini which handles files fine.
What I am noticing, is that when I export the image from Lightroom into Sharpen AI, and then do my edits and save it so that it goes back into Lightroom, it appears the adjustments are not saved?
If I look at the image in the Develop tab in Lightroom it looks the same, however when I look at the same adjusted image in the library tab (in Lightroom), it shows the correct edited version.
How can I fix this?
