For the time being RAW files, that is all, are not supported. You can still open the RAW file in Studio and execute Sharpen AI through the Studio Plug-ins menu.
It has already been mentioned that the PS plugin problem is being looked at.
I just installed 1.0.8 update and now Sharpen AI opens in Photoshop on MacOS. Thanks for a speedy fix!!
Whereâs the update?
Never mind. Just got it going. Kudos to Topaz for the quick redressal.
Click check for updates under help.
Same problem for me.
Have you upgraded to the latest version which is v1.0.9?
If you havenât go to Help-> Check For Software Updates and upgrade to see if that makes a difference.
Yes I have the latest versions thanks, now working in Photoshop but not Studio.
I installed the update and it runs well as a standalone on my top spec MacBook Pro, but it still doesnât run from Studio and also crashes Studio
I installed update and now AI Sharpen freezes when opened , I checked for plugin and its not installed. I deleted everything and reinstalled- same thing happens. I was working in standalone before the latest update.
MAC OS 10.14.3 MacBook Pro
As others have reported, 1.0.9 works in Photoshop (and standalone, in my case), but now crashes in Studio as it previously did in Photoshop (loading dialog flash, then, after a few seconds, a crash dialog, but Studio is still responsive). I didnât test in Studio with the original release, so Iâm not sure if this is a change.
2018 iMac Pro
2 Issues:
Process: Topaz Studio [714]
Path: /Applications/Topaz Studio/Topaz Studio.app/Contents/MacOS/Topaz Studio
Identifier: Topaz Studio
Version: 1.14.0 (1.14.0)
Code Type: X86-64 (Native)
Parent Process: Topaz Studio [681]
Responsible: Topaz Studio [714]
User ID: 501
Date/Time: 2019-03-02 15:34:02.372 -0600
OS Version: Mac OS X 10.14.3 (18D109)
Report Version: 12
Anonymous UUID: FD1B0D34-3E56-0CDB-2F64-4CF305D92372
Time Awake Since Boot: 300 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace OBJC, Code 0x1
Downloaded new Studio update (v1.14.3), Sharpen AI now works as a plug-in.
