Hi.
Problem:
I went to launch the app - Photo AI v3.0.4.0. Upper right corner said 2 updates.
During the installation it said some need to be done after a reboot.
The reboot started - Lenovo’s Logo was on screen and a revolving circle was running.
After about 10 minutes, I held in the power button to turn it off. I waited a few minutes then went to power it up again - same issue: didn’t reboot!
On third attempt, I hit function key to do a auto fix. It powered up - YEAH!
I launched Photo AI, a window gave me info on light and dark. About says it’s version 3.0.4.
Do you want log files, etc.?
Computer:
Lenovo Slim Pro 9 14IRP8 - Type 83BV, 32 GB RAM, Dual display cards. Windows 11 Pro, 64 bit.
to reproduce issue:
- Step 1
- Step 2
- Step 3
