Selection Lag for RAW makes it unusable
System Specs: 2022 M1 MAX 64gb RAM
When trying to edit a selection the lag in movement of the image and brush makes the process unusable. I have deleted the entire application, rebooted and reinstalled it several times with no noticeable improvement.
Steps to reproduce issue:
  1. Plug-in Extras, Process with Topaz AI
  2. Sharpen “Subject Only”
  3. Edit subject
Using NEF files shot on D850
I’m experiencing severe lag on selection editing as well, using NEF files from Z9.
(M2 Max, 32GB, Sonoma 14.4)
Topaz Labs Download Page
Unfortunately, doing this didn’t change anything; editing a selection is still very laggy.
Please reach out to us at the following link:
Topaz Labs | Support Page
I just see a couple of articles on there that don’t address this. Is there supposed to be something else?
At the bottom right corner of the Support Page you should see a pop-up window that allows you to send in a support ticket to our team. You can also send in an email to us at help@topazlabs.com
