I sometimes see issues when switching between add/subtract when using the brush when selecting the subject. If I subtract from the subject and then I add to it in other places, the part I just subtracted gets added back again. This doesn’t always happen.
Also, I see when I am painting to subtract, the brush adds back near the part I am erasing.
