Many modern applications let you select the GPU to use from within the application, is it possible that the switch can be done in Topaz products and then remembered via Registry Options?
@russelltarpley may want to ask the developers.
Would be a god addition to TS.
As a god myself, I think the GPU selection is already in each application (Topaz Studio, Sharpen AI, Gigapixel AI, Etc). Adjustments within TS are not separate applications. I command it be left as is.
