When you enable second enhancement, both enhancements wil use the source video as the basis for their settings. Doing separate enhancement runs means the second will use the results of the first. Depending on which models you’re using, the results may be very different or not noticeable at all.
So generally how understand which model to use?
Maybe first protheus manual and then theia fidelity?
Have both fix compressions, sharpen and reduce noise…set value on protheus and leave 0 at theia?
Also value for intermediate…I set auto but dont know…
One remark: You should avoid providing an advise to a person by saying “Bottom field first” , because his/hers video field order might be “Top field first” (My SD videos some are TFF and others are BFF).
if he/she uses the wrong field order the video will flicker/stutter.
Even though you described your own personal flow, the person might think he needs to follow the exact parameters, hence he might select the wrong field order.
here is the advisable way that would avoid confusion:
1. Dione V3 1:1, Bottom field first (you might need to select "Top Field fists", depends on your Source. to be on the safe side, better you select "Auto")
