The bug / behavior you have encountered
When using, “Second Enhancement”, and selecting, “Artemis” as the Second Enhancement’s AI Model, the, “Input Conditions” drop-down box is not suppled in the UI under the Second Enhancement settings such as it is when Artemis is the First Enhancement. As such, it uses the Artemis Medium (MQ / ALQ12) model versus what I want, which is Low (LQ / ALQ13) model. -
Your system profile
Topaz Video AI version 4.0.4
ASROCK X99 Extreme4 + Intel(R) Core™ i7-5820K CPU @ 3.30GHz, 3201 Mhz, 6 Core(s), 12 Logical Processor(s) overclocked to 4.0GHz
NVIDIA GeForce RTX 2060 SUPER + Studio Driver 535.98
Windows 11 Professional 22H2 (22621.2428 w/ Feature Pack 1000.22674.1000.0) -
Your log files (Help > Logging > Get Logs for Support)
Logs contain excessive amount of PII and, as such, will not be supplied. As a software developer, I have reviewed the logs and find no output which pertains to the Second Enhancement (either by function or by timestamps). -
Any screenshots as necessary
My actual export settings:
Demonstration of the field I am expecting and where it should be:
Topaz Video AI - Version
