Saving JPG with no JPG compression option
Hi,
I was wondering if you can include an option for when for saving JPG (overwriting existing JPG) file that the program do not apply JPG compression on the JPG file ?
Thanks.
Kind regards,
David
Hi, you can save a JPEG at 100% quality within the standalone version of Photo AI
After processing your image in Photo AI, select Export Image, and the Export Window will open under Format select JPEG if not there already, you’ll see the Quality Slider set this slider to 100% and click Save
Hope this helps
Thank you fore your reply.
Is there a different between a .jpg and a .jpeg file ? What if I need to do a batch process with auto save, will this batch process also save each photo in no compression (ie. 100%) or do I need to save each phot manually ? Thanks.
Hello again, no there’s no difference between JPG & JPEG and yes 100% will be saved to all images.
Bonus Tip:
If you send a JPEG image to Photo AI or Gigapixel AI and save it as a TIFF file, Topaz use a tech that they called JPEG to RAW which is incorporated into Photo AI & Gigapixel and converts your 8-bit image to a full scale 16-bit RAW file. However, technically it’s not a RAW file in the true sense of the word but, you’ll be hard pressed to tell the difference
thank you for your reply and info once again. Much appreciated.
