Saving DNG from RAW creates an error
I have installed Version 2.3.0. Since this version, RAWs from the Lumix G9II (RW2 files) are compatible with Topaz Photo AI.
I opened the RAW files from Lightroom via additional Modules and wanted to save it after editing as .dng file to Lightroom.
Then the error message came
The same problem occures, when I open the .RW2 fikles directly in Topaz.
Please solve that problem with saving the edited RWA files to .dng files.
Regards
Dieter Knüttel
Topaz Photo AI [v2.3.0] on [Windows]
Addition:
When I import dicectly into Topaz Photo AI the following applies:
When I go to Edit - Preferences and there Export and switch use Adobr DNG SDK for exort OFF, the dsaving as .dng file works. If I switch it on, the reaction is as described and shown in the pictures above.
When I am in Lightroom and open the RAW file via extra modules, I can save in Topaz, but Lightroom does not import the picture with the following notice:
DNG-Error-Lightroom
Same camera, same software, same problem … yes, please fix the bug
Same for me. The latest update did not solve the problems as stated above.
