When trying to save or export NEF-Files I do not get the choice anymore wether to use dng or jpg. I can’t do veryy much with dng, because before further processing I have to transorm the format anyway. Very annoying is, that after processing the program completely shuts down, I do not find any possibility (settings) to avoid this. This issue causes a very bad workflow.
Steps to reproduce issue:
Step 1 get a rather big NEF-File (60 Mb or bigger)
it is really strange, after shut down and restart, everything s working as usual. Bay the way, I am running Windows 10 and I have just download3d the recent update.
/-------------------------------------------!!!KERNEL HEADER ERRORS FOUND!!!-------------------------------------------
Error in CISA routine with name: kernel
Error Message: Input V38 = [256, 260) intersects with V37 = [256, 260)
Error Message: Explicit input 2 must not follow an implicit input 0
the the program is shut down and the processing is omitted.
Also if you can, please try to recreate this crash in Topaz Photo AI, then go to Help > Open Log Folder, please send me all of the files within that folder. You should be able to attach them directly as a response to this thread.
If you would prefer you can securely submit your files(s) to my Dropbox using the link below. Make sure to send me a note to let me know you sent something.
As I said before, this error occurs when processing one file only! And, when doing this I do not have options like “save as”, i.e. chosing another filename.
Kernel error message is as follows:
Instruction / Operand / Region Errors:
Additionally to this problem I’d like to know, why the cursor is swinging when using the edit selection. What I mean is: I move the mouse 1 inch upward and stop there, but on the screen the selection circle moves up further until it stops. This way it is almost impossible to make a decent selection. The same problem occurs regardless the direction of the mouse moves. I also tried out with a HANVON drawing board, but it does the same.
I wonder, what I am doing. I reported several times, to have massive problems. Everytime I process one single file, I get a Kernel-error. Additionally the handling of the cursor when trying to select an object is almost impossible. I thought, that somebody is working on that issue. You received several times my logs etc. I uninstalled, reinstalled and so on, but the problem still remains.
