Save RAW as DNG
Hello,
Problem is, if I save a RAW as DNG then the DNG gets a green tint. This is not the case when I save in Tiff. My camera is the OM1-M1 . No matter what I edit, even on autopilot, there is always a green cast.
It would be nice if you could fix this because the Tiff files are too big for me. If required I can also provide the RAW’s of the camera.
Regards
Stefan
Topaz Photo AI [v2.3.2] on [Windows]
  1. The original image file.
  2. The processed image.
Dropbox File Request
Hello, I am currently trying to upload files.
I have left everything on automatic, so I have not set anything. I have 2 images, each as ORF(RAW), DNG (with this green tint) and a Tiff that does not have this green tint. I hope you can help. This actually affects every photo, not just one. When I save in DNG, the photo loses its natural colour tone, but not in Tiff. I have not yet tried other saving methods.
Kind regards
Stefan
Translated with DeepL.com (free version)
Topaz Labs | Support Page
