Saturation and white-balance problems continue
Since the updates from AI v.1.3.0 there is an increase of saturation problems. Topaz is changing white balance and adds saturation to the images. Look at these two images. One is from Lightroom and the other from Topaz. The picture is taken 11.30 at night in Northern Sweden and therefore the special light. Look at the change of color in Topaz. Look at the green grass and trees.
@marco.helles Thanks for reaching out.
Please upload the original RAW file here so we can run some tests on our end.
In the meantime, you can try using the Photo > Edit in > Topaz Photo AI workflow which will preserve color and process a TIF instead of a RAW.
I did this before, he has files. But I can send you new ones if you need.
This is the last try I made. Nordic midnight photo. See the shift. In production. These are exported Jpegs from ORF.
<img width=“1659” height=“1244” style=“width:17.2812in;height:12.9583in” id=“Bildobjekt_x0020_8” src=“//discourseupload.s3.dualstack.us-east-1.amazonaws.com/original/3X/9/8/9880e0807f8688acf3d913784c4ce2c957d76d49.jpeg” alt="En bild som visar person, utomhus, leende, himmel
Automatiskt genererad beskrivning">
<img width=“1659” height=“1244” style=“width:17.2812in;height:12.9583in” id=“Bildobjekt_x0020_9” src=“//discourseupload.s3.dualstack.us-east-1.amazonaws.com/original/3X/f/3/f3b7316777fe7d488698d63f5d888a816da8e8a4.jpeg” alt="En bild som visar person, klädsel, utomhus, leende
Lingyu Product Specialist
June 6
Thanks for sending the files Marco. I processed the files in v1.3.7 and saw a color shift on importing the RAW to Topaz Photo AI but the export color was very close to the original.
Here is a video of what I see on my computer. Do you have antivirus or any other applications on your computer that could be blocking Topaz Photo AI from saving the file correctly?
June 9
We will be working on the OM-1 color shifts soon as it is one of the most popular cameras that used with Topaz Photo AI.
I sent you some images earlier. Look at these two. See the skin color and how the green gets saturated and the bricks in the background gets more red.
