Samsung "Expert Raw DNG" Format not accepted
Photo AI 3.3.1
Samsung RAW (.dng) images created with the “Expert RAW” setting cannot be opened.
Error msg “Image is not supported”
Other .dng images work properly
Windows 11
What camera model are you creating these RAW files with?
Samsung Galaxy S244 Ultra
I don’t want to search the Internet, but probably this RAW is encoded using the new JPEG XL codec, which unfortunately Topaz has not yet added to its products.
  1. The original image file.
  2. The processed image.
Dropbox File Request
I will, but there are no adjustments or settings. The file simply cannot be opened.
Jerry Barton
Vienna, Austria
www.jerrybarton.eu jerrybarton@iname.com
Nov 5, 2024 16:44:29 John S via Topaz Community <noreply@topazlabs.com>:
one file uploaded. Original from Samsung Expert Raw.
Error msg:
Thanks for sending in that file. I can confirm that this camera model is not currently supported in Photo AI currently. I have forwarded this information to the development team for further investigation to possibly support it in the future.
We use a software to read camera RAW files which needs to be updated with new camera models as they come out. Once LibRaw has support for this file we will also add it.
Thank you.
Jerry Barton
