Hi there, Topaz is just running so very slow. I’ve restarted, closed other apps, nothing seems to help. Finally got an update notice, installed, restarted again, still running S…L…O…W please advise?
Update, I completely uninstalled and reinstalled Topaz and I’m still having the same problem. This is on a nearly new MacBook Pro and I’ve never had this issue before.
