Running multiple instances via command line issue
Hi, I successfully ran the export via the command line but couldn’t let it work on multiple files simultaneously.
Here is the command that I’m using
for /r “D:\dump\qq\group1” %i in (*.mp4) do ffmpeg “-hide_banner” “-i” “%i” “-sws_flags” “spline+accurate_rnd+full_chroma_int” “-filter_complex” “tvai_up=model=prob-4:scale=0:w=1440:h=1080:preblur=0.0425178:noise=0.0299358:details=0.5:halo=0.02:blur=0.22795299999999996:compression=0.645083:prenoise=0.02:blend=0.2:device=0:vram=1:instances=2,scale=w=1440:h=1080:flags=lanczos:threads=0” “-c:v” “h264_nvenc” “-profile:v” “high” “-pix_fmt” “yuv420p” “-g” “30” “-preset” “p7” “-tune” “hq” “-rc” “constqp” “-qp” “18” “-rc-lookahead” “20” “-spatial_aq” “1” “-aq-strength” “15” “-b:v” “0” “-map” “0:a?” “-map_metadata:s:a:0” “0:s:a:0” “-c:a” “copy” “-bsf:a:0” “aac_adtstoasc” “-map_metadata” “0” “-map_metadata:s:v” “0:s:v” “-movflags” “frag_keyframe+empty_moov+delay_moov+use_metadata_tags+write_colr” “-bf” “0” “-metadata” “videoai=Enhanced using prob-4; mode: manual; revert compression at 64.50829999999999; recover details at 50; sharpen at 22.795299999999997; reduce noise at 2.9935799999999997; dehalo at 2; anti-alias/deblur at 4.25178; focus fix Off; add noise at 2; and recover original detail at 20. Changed resolution to 1440x1080” “D:\dump\qq\output%~ni.mp4”
and my second command is the same but with group2 folder instead and in a second command prompt.
that means it should do two files at a time one from each folder.
the problem is when I run the second command it aborts the files on group2 one by one and also group1 command starts acting the same.
someone said use && and strip the commands together for each file instead of using " For "
but I have more than 100 videos it’s going to be a headache also I don’t think it’s going t do multiple instances at once.
keep in mind I’m using the command prompt from inside the app. and the prompt works fine with the first command above alone even after I close the GUI …
also running a single file export on each prompt window give the same results so the issue is not with " for " command.
any suggestions will be appreciated.
Set your environment variables. Here’s the documentation.
Change your commands into batch files. Once those variables are set, you can run TVAI from any command prompt—so also from bat files.
This solution is for continuous exporting not for simultaneous exporting.
I have no issues running two simultaneously. I’m not opening the command prompt from the UI though.
I agree that sequentially makes more sense. With my hardware, running parallel only saves about 3 minutes for every hour of video. (I had to run 9 hours worth of video to save about 30 minutes of processing time.)
Did you change the output folder for the group2 command?
No, I actually didn’t change the output folder for the group2
so this might be the problem?
Will try that and let you know
