I wanted to try version 2.0.0 two weeks ago but I ran into a problem…
I normally use version 1.8.1 because it does what I want.
1)an the installer of 2.0.0.
It is not a clean install, keeping the previous version.
1.8.1 is in programfiles\topazveia181
2.0.0 is in programfiles\topazveia200
2) I open 2.0.0. I test Theia and notice it does not anything.
3) I decide to go back to 1.8.1 and the result had completely changed.
Instead of cleaning noise, it added noise. A lot of noise all over the picture : green and red dots.
It looks like the 2.0.0 installation altered the 1.8.1 processing.
Has anyone else experienced the problem?
The only solution was to uninstall both 1.8.1 and 2.0.0 and then reinstall 1.8.1.
