Steps to reproduce issue:
- Starting with an image that is 1080 x 1920.
- In the Crop tool, rotate it 30ish degrees, unlock aspect ratio, and crop a custom aspect ratio, about 1/3 of the original image height.
- Apply Facial enhancement and upscale the default amount - usually around 2x
- Quick Export button.
Image comes out totally distorted.
This issue only appears when you rotate the image. Cropping works properly if image is not rotated.
