I cannot rotate the input and set a custom resolution anymore with latest build.
Try unchecking the Aspect Ratio lock, does that allow you to enter a custom width as well with the height?
Which version are you using for this?
v5.5.1
without enhancement output resolution is 0x0 (Original):
This worked earlier.
@kyle.topazlabs : Did you try to rotate a video? What does it show for you?
In the preview it shows either 0x0 (no enhancement) or (nanx1080px) (with enhancement)
NAN : so some values are not calculated for some reason.
Unlocking the aspect ratio would work. (for custom resolution)
2x Upscale or 4x Upscale would not work.
I am able to see and rotate videos when imported into Video AI v5.5.1
Whats weird in your screenshot is that it is reading the video as a 0x0 resolution. Can you send the logs to the support email for us to look at? help@topazlabs.com
Include the link to this forum post as well.
Now it works for me too. Very, very strange.
I tried it several times. Also restarted the program. (I did not update to v6 yet)
I have no idea what caused the problem some days ago.
