So slow it’s just not useful.
Please send your system specification as your post doesn’t mean a thing Do you meet the minimum technical specs listed on the main website?
I absolutely do.
Please post your system specifications including CPU, RAM, GPU and dedicated vRAM and driver version for the GPU, otherwise just raise a support request at the main website.
Yes! Exactly!
The latest version is running ridiculously slow for me as well. Using a 2019 MacBook Pro, 2.4 GHz 8-Core Intel Core i9, AMD Radeon Pro 5500M 8 GB, Intel UHD Graphics 630 1536 MB and 64 GB 2667 MHz DDR4. For example, I was using it this morning to reduce motion blur on a source file that is 8256 pixels by 5504 pixels at 300 dpi and it took nearly an hour. The prior versions running the same task with similar settings were typically taking between 10 and 15 minutes per file.
