Resume renders design flaw
After exiting the program, the render progress is automatically saved. However, when the program is started again, instead of resuming the most recent export, it instead starts the next render in the queue. In addition, This will sometimes cause the first or most recent render to never finish. The easiest way to tell when this happens is if the GUI indicates two renders are occurring when the limit is one, and it will usually have animated “…” with a zero second ETA. When this happens, stopping the render won’t work and combined with the fact that copying settings doesn’t work (sometimes, from render queue context menu), this means the render will have to be resumed manually after closing it.
Will try and replicate this for the team to investigate.
