The team has discovered an issue with Sharpen in the latest version of Photo AI. We’ve tested this behavior on our side and were able also to reproduce this crash.
I’ve added your information to an ongoing support ticket we have open with the development team. We will contact you directly via this email once we have released a path to resolve this problem.
We are happy to inform you that the issue where stacking multiple Sharpen would cause the app to crash has been addressed in the latest release of Photo AI (v3.4.0). We recommend updating to this version, as it should resolve the problem you reported
You can download the latest version directly from the following link:
The program keep crashing while activating 2nd. command. for example Sharpen after Sharpen. The first one works successfully while the second one creates a crash
I tried to follow your suggestions with similar crashes but nothing helps
I tried to stack two sharpening layers in order to sharpen areas differently. I openned a secon sharpening and almost immediately the program shut down.
Topaz Photo AI on Windows 11
