With v1.3.5 calling File → Automate → Topaz Gigapixel… in Photoshop results in «The command “Topaz Gigapixel” could not be executed: the file could not be found.» or something similar. With v1.3.4 or Topaz Gigapixel plugin files from v1.3.4 it works normally.
I’m having the exact same issue “Topaz Gigapixel” could not be executed: the file could not be found. The Photoshop plugin stopped working in version 1.3.5 (MacOS 26.6.2, M2 Ultra 64GB RAM).
Hello!
This alert has been reported as a known issue:
The developers are investigating a cause and looking to implement a solution.
We will update this thread when a fix is found.
For now, the solution is to revert to the previous version
- Topaz Gigapixel v1.3.4 - Apple Silicon Mac: [Download]
This issue is now fixed in v1.3.6:
Apple Silicon Mac: Download
Write to us at help@topazlabs.com if there are issues.
