Resolved | Black Artifacts using Standard Max with Cloud
We are currently investigating an issue with Standard Max on the cloud. Our tests showed that the images were returning with black spots like in the example below.
Workaround
Rendering locally will work if your computer meets the minimum requirements for this generative model.
You can alternatively use the other generative models while we work on a fix.
This issue is now resolved. There is no need to update the version or perform any actions, the fix was released on the cloud.
If you have more issues, please reach out to help@topazlabs.com
