Resolution issue
So I’m exporting video with fallowing settings . I should get same resolution for out video . in reality I’m getting diferent resulution
Capture
Capture1
Hello,
Could you send us an email at help@topazlabs.com with the full log files from the app?
To gather logs, please select Help > Logging and make sure that there is a check mark next to File Logging. Next, recreate the issue and then return to the Help menu and select > Get Logs for Support and attach the “logsForSupport” file to your reply.
