Resolution Error
  1. Resolution Error every time I try to upscale to 8K
  2. Mac mini M2
Every time I try to upscale a video to 8k the process broke up with the Message: Resolution Error.
Change the encoder to h265 or ProRes and see if that fixes your issue. Most likely you still have the encoder set to h264 which can not handle the 8k resolution. If you run into an issue again share the logs so we can review what is happening.
