Every single video has a resoltuion error as a result. I cannot preview or process any video of any kind.
What encoder are you using and what resolution are you trying to export to?
I tried to export in h264 and h265, same results. upscale to HD
It tries to download and load a model but seems to fail to do so. With or without a VPN connection.
I also verified my Firewall = no rules for Topaz Video ai. I also updated my video drivers to the latest = still no go.
Do you have the same problem with ProRes? Can you share a screenshot? And any info about the system?
With Pro res I got Ai error instead of resolution error.
WINDOWS VERSION IS 11.23
CPUName: Intel(R) Core™ i9-9900K CPU @ 3.60GHz Thread Count: 16
MEM TOTAL: 31.9269 AVAIL: 24.6927
NVIDIA GeForce RTX 2080 Ti VRAM: 10.7822 GB
It doesn’t seem to be able download and load the model
You can manually download the models by running this script inside of the program (Process > Open Command Prompt)
https://community.topazlabs.com/uploads/short-url/ggU117xwa67P708TWHIHEoHbjfr.zip
I can see that it downloads the models. Once it is done, i wiil try again a video and let you know. Thank you for your help.
It Works!!! Thank you very much for your help. Have a nice day.
Great!
