Request | Batch Model Versioning
I would like to select two or more variations when batch exporting images on redefine, so for example, i would choose two output variations, creative 2, texture 2, and creativity 3 , texture 3. Then when it exports it will process the image twice before moving to the next image. similar to the compare feature on basic models but when it exports. I would also like the compare feature for the redefine on different settings
As a user of Gigapixel AI, I would like to be able to add to a processing queue some images to upscale and still, be able to work on other images in parallel and feed in that same queue. I would like to be able to send to that queue different processing variants of the same images. This need arose in particular with the release of the recover and redefine features which are all far more resource consuming (and thus time consuming) that the original upscaling models.
I would see the result as something similar to the queue management that can be seen on a software such as handbrake.
thats the reason I want to create multiple outputs from the redefine because it takes so long to process or preview them, so being able to add them to a que would be a way that could work.. there could be another button next to “export image” and say export to waiting que, you could then make the settings, send to que, adjust the settings send to que again until your ready to export them, then it processes all of them
Agreed, having an actual render queue that functions similar to Topaz Video AI would be very useful.
