I have a Mac M4Pro 64GB RAM. When I enlarged my videos from 720p to full HD 1080p, I always had a rendering speed of about 17fps. Now, after the last update, it is only about 8fps. Has anyone noticed this?
Which model are you using? Have you ran a benchmarking test?
Process > Benchmark
We have a user-sourced benchmarking page on our community forums that can give you a good idea of what speeds to expect from different systems. It’s hard to predict exactly how fast a specific task will process since it depends on the characteristics of the input file.
Still, encoding the same type/resolution video with the same model (and, of course settings) should not result in majorly different speeds.
