Removing Noise reset to autopilot back arrow is gone
I am using the Toaz Photo AI plugin for Photoshop
In the new version 2.1.0 the back arrow for using autopilot setting in removing noise is gone.
Until version 2.0.7 this back arrow appeared after scanning the picture.
I discovered a workaround but I hope you will give me back the back arrow without the workaround.
After scanning the picture TPAI says there is noise to remove and reverts to the setting from the last picture (or in case it is the first pictue I edit to autopilot)
Next to the slider to turn noise removal on/off there was (until version 2.0.7) a back arrow to set noise remove to autopilot settings. Now that arrow does not appear at first.
Only after turning noise remove off and on again the back arrow appears and is usable.
Topaz Photo AI (plugin for Photoshop) v2.1.0 on Windows
