Using Topaz Photo AI 2.0.5.
The Minor Deblur setting in the Removing Noise tab does far stronger sharpening than the Sharpening tab. I frequently cannot use denoise because the deblur sharpening is too strong and creates artifacts. This is with a Minor Deblur setting of 1. It does not allow me to set to 0 - I’d love to disable it. On a photo I’m editing right now I have sharpening with Standard V2 strength = 32. Minor deblur sharpens far more at a setting of 1.
Which AI model are you using with Remove Noise? Is it the non-Raw Normal, Strong, Extreme models or the Raw Normal or Raw Strong models?
This will help me identify which model we need to tweak for a better result.
