Just noticed on version 2.0.4 isn’t removing noise but increasing it.
Thanks for reaching out. Please send the following information so I can try to reproduce this.
- The original image file.
- The processed image.
- A screenshot or description of the settings panel so I can see what adjustments were turned on.
Dropbox File Request
I am having the same issue, and I uploaded the files you requested as well.
Thanks!
What settings did you use for this image? It looks like the sharpening may have increased the noise on the girl’s dress. You can decrease the sharpening amount or try other models to see if it gets a better result.
I’m sorry Lingyu. I thought I’d updated my problem. All is Good! Sorry about that my Friend!
