The original image file.
The processed image.
A screenshot or description of the settings panel so I can see what adjustments were turned on.
Uploaded Folder for you Use Remove on in the frames there is different location of the light cat.
Black cat is stationary.There is no way now for me to
sent a selection brush Like in Mask AI.
