Remove Noise Normal v2
Remove Noise Normal v2 is much worse on skin than v1. It produces more artifacts on quite noisy arms.
Topaz Photo AI v1.3.7 on Windows
Hi @ilja.muller, are you able to provide screenshots of the before/after you’re seeing with Remove Noise V2? I can pass these along to the team. If you have the original files that you can share with us that would be great as well!
