Remove does not replace
The new 3 version is hard to find - it does not occur on the right lower screen under “here are a few more ideas…”.
When using the remove tool, it seems not to replace the removed object by backgound - I coninously get a coloured square. What do I do wrong?
Would you mind sharing some examples of these outputs you are receiving?
If you would like please take a screen recording of this behavior so I can see exactly what is happening.
Loom is a great free application for this: Loom | Free Screen & Video Recording
Please also send me your system profile information so I can check if your computer hardware is up to date.
