Does anyone know how to remove a Preset that I set up on Topaz Video AI?
Just go into the preset folder and delete that file
ProgramData\Topaz Labs LLC\Topaz Video AI
In my TVAI 3.1.2 (on Mac), I have a main menu item Edit | Delete Preset
Perhaps it’s different on Windows…
Andy
No different on Windows.
Thank you to everyone who responded. Clearly I am blind.
I only went into the File Menu once to set Preferences and haven’t revisited that menu. I made the incorrect assumption that it would exist as a button on the GUI that appears for the Preset Box. A Minus button next to the Plus button to delete presets would be ideal but now it rather makes sense that a feature people might use less often would be on a pull down menu.
