Removal of objects doesn’t work properly (continued)
Removal of objects doesn’t work properly (see pictures in attachment)
Tried it with several pictures: always the same pixeled result.
It used to work some weeks ago.
Topaz Photo AI [v3.0.4] on Windows
rainer.feldmeth
3d
I re-installed Topaz Photo AI and all data on D:\ after having deleted all folders on C:\ and D:
Interestingly Windows 10 “Apps and Features” shows Topaz Photo AI on C:
and there is a (new) empty model folder also on C:\ProgramData\ whereas the models are properly installed on D:\ProgramData
Could it be that there is a mixup between C:\ and D:\ due to my former installation of Topaz Photo AI on C:\ and therefore Topaz Photo AI can’t find the models for the removal function?
2024-07-02 20_49_16-Einstellungen
Maybe the installation logfile can help:
Topaz Photo AI Installer Log.txt (1.7 MB)
