I’ve had to reinstall windows 10. When I come to install AI I am prompted to activate my software. I press the button, sign on in the browser, get told my software will be activated but instead I get prompted that my browser’s Auth token has expired and I should press activate again. The browser then tells me it is going to close in 5 seconds and my application should be authenticated. It is not and I am in a loop.
Ideas?
Hi.
Here’s a link from Topaz that may help with your Activation issues
Here’s the to contact Topaz Support directly
Topazlabs Support
support@topazlabs.com
Hope this helps
If the steps linked in that docs page that AND-E shared do not help, please pull the logs from the app and send to the support team so that we can try and see what is going on.
@mark.phillips-3905 could be browser thing, which one you use, edge? Try different browser maybe it helps
