Hello,
I am using Topaz Video AI 6 since my system does not support the Starlight Mini tool that comes with versions from 7 onwards (not enough RAM).
I mainly use the software to upscale/enhance mid-quality videos from about 20 years ago with 720x540 resolution and 4:3 ratio. I have found the optimal enhancement settings to be 2x upscale applying Proteus combined with Dione Robust. In the “Input” settings box I set under “Input color override” both “Color space” and “Color primary” to BT470BG, leaving “Color TRC” auto-detected and “Color range” to full - this solves the yellowish tone issue that occurs when upscaling this type of 4:3 videos and I find the output to match the original colours as close as possible.
The result with the combined Proteus-Dione Robust enhancement is remarkable but the eyes become coloured with a reddish tone which is more noticeable in full shots and mostly disappears in close-up shots. This only happens when applying the second enhancement.
Has anyone experienced this issue before and might know how it could be solved?
Thanks in advance for any help
