I only want to enlarge at image to a height of 4800 pixels -far smaller than i was able to do with no problem using the previous version. I see my image blown up to about 500% on the screen and get the above warning
You get that warning if the source image is over 1000 pixels on a side, when selecting the recovery model.
There is nothing stopping you doing the upscale, but the recovery model takes alot longer than other models.
Thank you Allan, but I’ve never had a problem before the upgrade - I often upscaled from 3600 to 4800 with no problem at all.
If I really can’t get on with the new version, is it possible to go back to the previous.
Thanks again for your help.
Joan
Processing images with our Recovery Mode Beta model that are larger than the recommended 1000x1000 file size can cause unexpected conflicts.
This is intended as a warning and can be bypassed but expect the model to take quite some time for a files as large as the image you are processing. If you did not intend to use the Recovery Model on this image, please select a different model and your upscale should process as expected.
This functionality was similar with previous versions of Gigapixel when the the Beta Recovery Model was introduced.
